Install error 1 for AutoCad 2027 Education License
itservicesQ7F8M
Observer Observer
itservicesQ7F8M
Observer
Observer
Hi there, I am running into a persistent issue while trying to install AutoCad 2027 with Education licensing on entra-joined machines. I have been working with AutoDesk support for a few weeks but they have closed the case and asked me to try on the forums instead.
My goal: install AutoDesk 2027 with Education licensing on an Entra joined device with no entra user id bound. These devices are being shared by students in a school.
I’ve followed Autodesk’s recommended remediation steps (ODIS reset, Identity cleanup, local install path, disabling security controls), but I’m still seeing consistent failures.
If anyone has:
  • Seen similar behaviour on Entra-only or shared devices
  • Identified the cause of the LogAnalyzer crash
  • Found a reliable deployment method
Details:
  • Device: HP EliteBook x360 1040 G8
  • Operating system: Windows
    Operating system version: 10.0.26100.8390
    Operating system language: en-US
    Operating system edition: Pro
    Operating system SKU: Windows 10/11 Professional (48)​
  • Join type: Entra-joined only
  • Install context: Local administrator account
  • Tested with & wiped between:
    • LAPS account while on Guest Mode
    • Local account in the administrator group
I have followed troubleshooting articles provided by support and have gotten to two different failure points:
1. Installer reaches ~70–80% then rolls back
Autodesk installer launches (grey install screen)
Progress reaches around 70–80%
Installer then rolls back
Final result: Error 1
2. Installer crashes before full UI loads
White Autodesk installer window shows: “Preparing for installation”
Installer closes/crashes without progressing further
During the failed install attempts, Windows Application logs consistently show a crash within the Autodesk installer (ODIS):
Primary crash:
Faulting application name: LogAnalyzer.exe
Path: C:\Program Files\Autodesk\AdODIS\V1\Setup\LogAnalyzer.exe
Exception code: 0xc0000409
Event ID: 1000 (Application Error)
Windows Error Reporting entry:
Event Name: BEX64
Application: LogAnalyzer.exe
Exception Code: c0000409
I can also see that the product is removed after the install fails
Product: Autodesk CER -- Installation completed successfully.
Product: Autodesk CER -- Removal completed successfully.
Windows Installer removed the product.
There is also an entry indicating the system flagged a restart condition during install but nothing is prompted in the UI
Machine restart is required.
I have been at this for a couple of months now, this is the troubleshooting I have tried as supplied by AutoDesk support:
System Troubleshooting
  • Rebuilt device multiple times - tried different admin accounts such as LAPS and also using custom ora uri to create a local admin account on the machine during autopilot deployment
  • Confirmed no pending Windows updates
  • Uninstalled and reinstalled Microsoft Visual C++ redistributables
  • Installed Autodesk Licensing Service separately
  • Downloaded fresh installers multiple times
  • Extracted installer to local path instead of downloads folder:C:\AutodeskInstall
  • Confirmed admin account had security access to read/write in C drive
  • Not running from OneDrive/SharePoint
Security:
  • Disabled:
    • Microsoft Defender placed in troubleshooting mode (including endpoint protection)
    • Web filtering
  • No VPN in use
  • Same network successfully installs AutoCAD on hybrid-joined devices
Other info:
  • Installation has worked on hybrid-joined devices using the same network & hardware
  • Fails consistently on Entra-only devices
  • Installer behaviour is inconsistent:
    • Either crashes early, or rolls back at ~70–80%
  • Logs consistently point to a crash in:
    • AdODIS\V1\Setup\LogAnalyzer.exe
  • At least part of the install chain succeeds before rollback (CER component)
  • No obvious network or certificate issues
  • Expired Trusted Certificates
    These are updating fine
Guides followed so far:
Nothing happens after the “Preparing for installation…” when installing an Autodesk product 2021 or ...
How to remove and reinstall Microsoft Visual C++ Redistributables packages
Thank you so much!
Simon_Weel
itservicesQ7F8M
Observer
Observer
Hi Simon, I have tried the full package, the online installer, and tried to make a deployment package.
I have followed the first guide, the instructions in the second guide were also provided to me by AutoDesk Support.
Simon_Weel
You could try to install the latest version of ODIS first: How to download the latest version of Autodesk ODIS
CER is 'Customer Error Reporting'. The latest version is included with Identity Manager, although the release notes don't mention that: Autodesk Identity Manager component update for product versions 2024 and beyond (Windows)
Have them installed first and then give it a go....
pkomatlapalli
Hi @itservicesQ7F8M ,
We would like to follow up on this issue. Have you tried doing  Simon_Weel response to resolve your issue. If yes, please click on the Accepted Solution button, It would be very helpful for others who may encounter the same issue in the future.
Pavan Kumar | Community Manager
itservicesQ7F8M
Observer
Observer
Thank you, AutoDesk support also provided this as a solution when I was working with their team, but this unfortunately didn't fix my issue.
I've started to work backwards by rebuilding our SOE and can see there is an Intune configuration policy that is blocking the installation, I haven't been able to track down which one yet.
I will report back if I manage to isolate it.
