IDSP install with Civil3D license
We are about to begin migrating to 2018 and want to simplify the deployment options for users.
All of our users are on subscription licenses, some with full IDSP and some with just Civil 3D.
What happens if we deploy IDSP 2018 to all users, but a user logs in with only a Civil 3D license attached? Will Civil 3D still work as expected but the other packages just don't work? Or will they not be able to use Civil 3D either?
Darin.Green
@Anonymous
Not sure what you mean by...
Maybe you're just using the original term "Subscription"... Subscription licenses are now term based and your licenses are Maintenance licenses. I know it's maintenance because you still have suites. Is that correct, or did you upgrade your maintenance licenses to subscription (Term) licenses?
It make a big difference as suites aren't available for subscription and no longer sold as a product.
Answer: (if you have maintenance licenses)
You should build a network deployment from the suite with all of the products included. Afterwards, you should navigate to the Tools folder and use Create/Modify Deployment shortcut to create another configuration from the existing configuration but this time uncheck all of the products except Civil 3D.
The idea behind this is to have one deployment with multiple shortcuts that reference separate ini files to install the necessary products.
Let me know if you moved to subscription.
If this information was helpful, please consider using the Accept Solution
Hmm yeah I'm not sure what you mean. We used to have on-prem network licenses for IDSP that were shared, using the license manager. We then moved our design team to named (managed) subscriptions that are managed through the online portal and assigned to each individual user using their AutoDesk ID. The portal still calls it IDSP 2018.
I understand that I can create multiple deployments to satisfy the different requirements,that's what I am trying to avoid. We use SCCM and the users access these through Software Center, I would prefer it if we only needed to manage a single package.
Darin.Green
@Anonymous
Your company may have moved your suite licenses over to Collection licenses. However, you can only move to the same license type as your maintenance, so you guys may have kept your suites on maintenance and purchased new Single-User licenses...
The suite deployment should be configured as a Standalone deployment. The user would only be able to use the product that's been assigned to them. So, if you install the entire suite on the machine and the user only has access to C3D, then that's all he'll be able to use. In addition, if that same user need Navisworks, you can convert the license for Navisworks to network while C3D maintains the Single-User license.
Hope that make sense.
