I have concerns about my copy of ACAD LT 2018
Robertewolter
Message 1 of 13
Robertewolter
I have concerns about my copy of ACAD LT 2018.
Who should I address them to?
Replies (12)
Message 2 of 13
DarrenP
what kind of concerns?
DarrenP
Message 3 of 13
pendean
Community Legend
Community Legend
Message 4 of 13
Robertewolter
I noticed that someone had the same problem I had with his copy not loading. it was suggested that I install and reinstall. That worked for me. One of the replies I got made the comment that I should enjoy it while I can.
Is my copy going to stop working?
Message 5 of 13
mdavis22569
@Robertewolter
Share more details that you're experiencing
Getting an error message ...?
Mike Davis
Message 6 of 13
pendean
Community Legend
Community Legend
Do you mean this reply https://forums.autodesk.com/t5/installation-licensing/i-just-installed-an-update-for-autocad-lt2018-...
You seem to be having quite the software issue with LT2018 lately, do you just need a better more stable computer? And is your LT2018 fully updated (ABOUT command inside the program will confirm if you have 2018.1.2 installed) https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Update...
Message 7 of 13
Robertewolter
on 02-16 I posted about my copy not loading and got a solution.
one of the comments was " Also, of you're on 2018, and subscription, access will end when 2024 comes out  "
that is what I trying to find out
Message 8 of 13
DarrenP
if your asking if Autodesk will shut off activation of your 2018 then no
if they had this ability they would shut off everybodys activation of unsupported versions
DarrenP
Message 9 of 13
Robertewolter
thank you.
the term "unsupported versions" means what.
Just a little about me I've been using ACAD for over 35 years and made a living doing architecture drafting for 10 of those. Other then really enjoying the program (use it for my own projects now) I have a very extensive library of drawings I don't want to loose.
are there any options for the future.
Message 10 of 13
mdavis22569
@Robertewolter
For:
If you're on subscription then the answer would be NO ..  as 2018 wouldn't be part of the 5 prior versions.
2024 then 2023,22,21,20,19 ... that's it. Otherwise you're not in compliance with the licensing / subscription agreement.
Mike Davis
Message 11 of 13
DarrenP
it means they will stop providing links to download the software if you don’t have the physical media anymore
they are already stopped providing technical support & providing updates next step if they will stop providing activation codes for this version
the files are your files Autodesk does not go in to your computer and delete your files your responsible for backing up your files to the cloud or som
DarrenP
Message 12 of 13
Simon_Weel
It all depends on the kind of license you have. To check, click About under the question mark in the upper right corner and then Manage license. If it reads 'user license' then you are on subscription. If it reads something like 'perpetual' you have a lifetime license. If you are on subscription, then you have to pay Autodesk a fee on a regular basis. If you don't pay, you're not allowed to use the product anymore. If you have a valid subscription, then there's something called 'previous versions' which, if granted, means you can use a version not covered by the license. But if you are on subscription, I wouldn't go that way but instead install a newer version.
If you have a perpetual license, then you're free to use it 'as-is' as long as you like, but with new versions of Windows emerging, sooner or later it won't run anymore. Also, version 2018 is no longer supported which basically means there will be no updates to address problems.
Message 13 of 13
mdavis22569
Or just look in the account manager:
https://accounts.autodesk.com/logon?resume=%2Fas%2F8eGNyuSHpD%2Fresume%2Fas%2Fauthorization.ping&spe...
Mike Davis
