I can only run my Autodesk software in admin mode.
rib_diogo
rib_diogo
As title says, I can only run my Autodesk software (Motion Builder 17 and 18, Maya 16 and 17) as admin. I've already tried to find a solution, but couldn't find.
Any help?
Mark.Lancaster
@rib_diogo
And is there any error message when you don't have admin rights?
Mark Lancaster
rib_diogo
There are no errors at all. I can even see Maya for a brief second in windows task manager. Basically “nothing “ happens.
Mark.Lancaster
@rib_diogo
I would start here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable...
Did this work in the past and now its now or its never ran?
Mark Lancaster
rib_diogo
It used to work.
Thanks for that solution. I’ve already tried that, but I’ll try it again later.
rib_diogo
@Mark.Lancaster
So, I've tried all that again, but still not working.
I've already tried to repair/install and still the same problem.
Thanks for your help anyway.
rib_diogo
I solved this by re installing my OS.
