Help, AutoCadLT2016 in Widnows11 Fatal Error Issue
jiaFZTCJ
Observer Observer
jiaFZTCJ
Observer
Observer
Hello, I am getting a fatal error on my autocad LT 2016 product. I am using Windows 11. I tried to reinstall, reset settings, disabled hardware acceleration. Any suggestions would be helpful. They get error frequently whenever they relaunch the software, reloading a file, or attaching an image.
[ The subject line of this post has been edited for clarity by @pendean Original: Help, AutoCad Fatal Error Issue ]
pendean
Community Legend
Community Legend
Greetings @ jiaFZTCJ
Windows 11 is your problem: roll back to Win10 (yes, it might cost you money, you skipped over the research first perhaps?) if installing this update does not fix it https://www.cadlinecommunity.co.uk/hc/en-us/articles/205117351-Autodesk-AutoCAD-2016-Service-Pack-1-...
mdavis22569
If you look at the system requirements you'd see:
Autodesk has confirmed that AutoCAD and toolset 2021 and 2022 are fully supported in Windows 11. Autodesk does recommend updating all hardware drivers to be used in Windows 11 before installing AutoCAD.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Will-AutoCAD-based...
Mike Davis
