Having to sign in every time I open AutoCAD
Is this new system with no serial numbers actually any better than serial numbers? i have to sign in every time I open AutoCAD - this is very inefficient and rather annoying. Is this how all versions of AutoCAd will run past 2019? I think I'll keep using 2019 if so.
Mark.Lancaster
@Anonymous
This is the sign in option but you should only have to do it once..   Did you enable the 2 step verification process where a code is sent to your mobile device?
Perhaps you want to review this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/You-Autodesk-software-keeps-asking-you-to-login-every-time-you-open-it.html
Mark Lancaster
