Getting AutoCAD LT 2011 onto my computer
I have a CD version of AutoCAD LT 2011 but my computer does not have a disk drive so I can not install the software.  Is there a way where I can download Autocad online and use my product key/ serial number to to confirm that I actually have the software purchased?
Otto
Hello brad.weber87F7B and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
I  do have an issue downloading the software because I have a CD with autocad on it but no CD drive to put the CD into my computer to let it download.  Is there a way to download AutoCAD LT 2011 online and then confirm my CD purchase of autocad via the serial number/ product key that came with my CD?  Thanks
rkmcswain
Get someone with a CD drive to copy the CD to a flash drive.
Or borrow/buy an external CD-drive.
You are not going to find a legit LT2011 download out there.
Also, if your current PC is running Win8 or later, you might have issues getting 2011 to run (or run correctly) on it.
Those options might work, but i finally managed to find an online chat where I could talk to someone and tell them my problem.  They then sent me a link to download AutoCAD LT 2011 and from there I was able to put in my product key/serial number.  The system worked and my problem is solved.  Thanks for everyone's help.
rkmcswain
Interesting. Maybe you could post the URL to this download so future readers of this thread can benefit also.
