Fusion - Is it possible to roll updates back?
fpmachinebob
fpmachinebob
 Is it possible to roll the updates back about a year or two?
 Thanks , Bob
@fpmachinebob for clarity, @joaquim.moral has edited the original title: role back. Check out the community user guides for instructions on choosing the best title for your post. Thanks for participating!
Darin.Green
What application/updates are you referring to? Some updates may not allow you to uninstall them, so you may need to uninstall the Autodesk product in question, then install the base build.
If you're asking to install something like AutoCAD 2025 instead of AutoCAD 2026, then you can just install AutoCAD 2025 without uninstalling 2026.  Each version of the application can reside on a machine side-by-side.
If this information was helpful, please consider using the Accept Solution
fpmachinebob
Where can I find the list of updates that have been installed?
Darin.Green
Within the Autodesk application, go to Help > About and take not of the version i.e. 2024.3.2
