Fusion 360 'Startup' Ultimate version not showing Simulation selection
The ultimate version includes basic Simulation.  This link indicates the free Startup version should have ultimate package.   In Fusion 360 if I look at the 'About' it says:  'Active Plan:  Fusion 360 Ultimate, Startup', and then Expires Sept 5, 2019.
The version I installed about a month ago does not show Simulation modeling in the menu bar drop down.
Would the problem be:
  1. Need to download this next month?
  2. There is a way to turn on Simulation in current Fusion 360
  3.  I need to pay a subscription for the basic finite element analysis
-Thanks in advance
Mark.Lancaster
@Anonymous
There was no need to start another posting about this..  You could've continue with the other one..
Anyhow the link you provided is so out-of-date, many changes since then...  5 axis machining is included with Fusion 360 standard.
What version of Fusion or build # do you have?  It should state on the Help/About screen
Mark Lancaster
DarrenP
here are the changes: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/simplecontent/content/one-fusio...
if this wasn’t available before under the startup license it will not be available unless you start paying for a license
DarrenP
The version is 2.0.4567  --running this on Windows 10
Good link,  it indicates that Simulation should be there, so still not sure why I do not have it.  On my menu I have: Model, Patch, Sheet Metal, Render, Animation, CAM, Drawing.   Quoting from the link:
'Fusion 360 Startup/Hobbyist subscribers - There is no change to the startup/hobby subscription for Fusion 360 at this time. All users will continue to have access to all features. Note: generative design technology for Fusion 360 will only be accessible to commercial customers'
So either there should be a way to bring it in, or the above quote is inaccurate, and it is necessary to pay for it to get Simulation, which I would be willing to do, but would like some clarification.
Talked with sales and purchased licence, the free hobbyist version does not contain Simulation, FEA, so you are correct
