Message 1 of 11
- Mute
- Permalink
- Report
I have the Fusion 360 Admin Installer and the Documentation on how to install and update going forward. The issue is you have an 'install' command and an 'update' command. If a certain version is installed, then the 'install' command will fail, requiring the 'update' command. This can just be a pain to manage when there are so many different versions of the Application.
Is it possible to get an MSI for each version? Or allow for an '--install --update' which will install if it doesn't exist, and if it does exist, update it if necessary.
Thanks!
