FLEXnet Licensing error
I have downloaded and installed the latest edition v11.13.1.2 Build 173302 x64_n6 on 3 brand new servers running Window 2012 R2. Installed using default suggested path and then started LMTOOLS to create a new service. When i am finished i click "Save Service" and get an error message.
Updating DACL Failed
Service has been created but failed to update the DACL settings of FlexNet Licensing Service. It will give problem for accessing TS features. Check whether FlexNet Licensing Service is correctly installed or not and delete and create this service again
OK
I tried
https://forums.autodesk.com/t5/installation-licensing/flexnet-licensing-error-15-570/td-p/3061980
Same to mine:
Is there a solution for the problem?
Thank you Georg
