FLEXnet Licensing error
GeorgK
Advisor Advisor
Message 1 of 17
GeorgK
I have downloaded and installed the latest edition v11.13.1.2 Build 173302 x64_n6 on 3 brand new servers running Window 2012 R2. Installed using default suggested path and then started LMTOOLS to create a new service. When i am finished i click "Save Service" and get an error message.
Updating DACL Failed
Service has been created but failed to update the DACL settings of FlexNet Licensing Service. It will give problem for accessing TS features. Check whether FlexNet Licensing Service is correctly installed or not and delete and create this service again
OK
I tried
https://knowledge.autodesk.com/customer-service/network-license-administration/get-ready-network-lic...
https://knowledge.autodesk.com/customer-service/network-license-administration/install-and-configure...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Update-DACL-failed-when-...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/updating-d...
https://forums.autodesk.com/t5/installation-licensing/flexnet-licensing-error-15-570/td-p/3061980
https://forums.autodesk.com/t5/installation-licensing/flexnet-licensing-error-15-quot-winsock-operat...
Same to mine:
https://forums.autodesk.com/t5/installation-licensing/lmtools-fail-to-set-dacl-on-new-service/td-p/6...
Is there a solution for the problem?
Thank you Georg
Replies (16)
Message 2 of 17
Otto
Hello GeorgK
It looks like you are seeing "Error 15" when registering and activating software or using the Portable License Utility. The following article(s) should help you resolve the problem:
Port numbers for single server FLEXlm setup
Problems registering and activating software or using the Portable License Utility
Checklist for troubleshooting Activation and Licensing issues
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 17
GeorgK
Hello Otto,
I opened the firewall. The error stays. It´s a network license.
Georg
Message 4 of 17
rkmcswain
FYI: "Otto" is a bot. It won't respond.
I seem to recall that error message and moving on. Do you know if it's actually not working?
Have you tested it like this?
http://upandready.typepad.com/up_and_ready/2011/06/verifying-if-license-server-is-up-and-running-and...
Message 5 of 17
GeorgK
The server is responding on port 27000. The only thing which is not working is the "Configuration using Services".
Message 6 of 17
natasha.l
Hello @Anonymous,
Welcome back. Smiley Happy
This error is associated with a permissions problem with the debug.log file or an issue with the installation of LMtools. Take a look at, Update DACL failed when saving service within LMTOOLS
Let us know if you end up resolving this. Thank you.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 7 of 17
GeorgK
Hello @natasha.l,
this does not solve the problem. I saw this post
There is a problem with the license manager v11.13.1.2 under Windows 2012R2. But the solution does not work on my side.
Georg
Message 8 of 17
GeorgK
Is there any update in the case?
Message 9 of 17
rkmcswain
FYI @natasha.l - I have received this same error on the last 2 or 3 installs that I have performed of the NLM, and there has not been a problem at all. They all work just fine afterwards with no action taken. Posts #8 and #30 in this thread indicate that this message can be ignored (in some cases I suppose).
There are also many other suggestions in this same forum thread, in case you have not seen this @GeorgK
Message 10 of 17
natasha.l
Yes, this is correct this error does not have to do with your Autodesk service in LMtools. This issue is a non-Autodesk issue & has been reported to have no effect on the License Manager serving Autodesk products, if the proper permissions have been adjusted & everything is set up properly.
Hello @Anonymous,
Have you tried to ignore the message? Or check the other services running on the server or license manager?
You can also "ignore" the issue by following the steps below:
  1. Click Ok on the dialog box.
  2. Click Save again.
This time you will not receive the error message.
  1. Go to the Start/Stop/Reread tab
  2. Click Start Server
  3. Verify you have licenses by clicking "Perform Status Enquiry" on the "Server Status" tab.
Message 11 of 17
rkmcswain
Thanks @natasha.l - perhaps you can inform the author(s) of the aforementioned KB article so that it can be removed or edited to state what you said above.
Message 12 of 17
Mark.Lancaster
In most cases when this occurs..  Selecting save (saving the service again) as @natasha.l pointed out corrects the issue.  But when it doesn't the other articles/work flows listed come into play.  Smiley Wink
Mark Lancaster
Message 13 of 17
GeorgK
I tried to ignore the message and checked the other services running on the server or license manager.
The license is working only without the service. When I use the service then the license server does not start. It's not a problem with the rigthts. I have an admin account. I tried the different solutions from my first post. But no solution worked.
Why is the problem with the error message not beeing fixed?
Message 14 of 17
natasha.l
Hello @Anonymous,
Can you explain further what you mean by "the license is working only without the service"?
If you can pull licenses then there is a functioning Autodesk license service running & this message is popping up for some other reason. I will escalate this post for you & a support technician will be with you soon.
Thank you.
Message 15 of 17
rkmcswain
@GeorgK - have you opened a support case with Autodesk on this?
Message 16 of 17
natasha.l
Hello Everyone,
Yes, @Anonymous has a support request opened.
GeorgK you should have automatically received the notification & can see the case number posted below your first reply.
Thank you for posting & a support technician will be with you shortly.
Message 17 of 17
GeorgK
Hello @natasha.l,
you can start the licenseserver with or without the service. See number 4:
The licenseserver works on my side without the service. The service is created but could not be started. I delete the service and did uninstalled the licenseserver. With a new installation the error occurs again. No change!
