Flexnet Licensing Error: -4,147 and -4,132
I've looked all over to figure out this error. My licensing server says that there are available licenses but the client is saying it is maxed out. This is affecting two computers in my office. I've attached a screenshot displaying this error. The message comes up with about 10 different Feature Codes.
Mark.Lancaster
@Anonymous
We would need to see the debug log file that's specified under the config service tab of your LMTOOLS.  Although the log file contains machine names there's nothing in there that would impact your environment if shared.  Also one entry indicates something is wrong with your license file or its not syntax properly.
Mark Lancaster
natasha.l
Hello @Anonymous,
This error can indicate that the LICPATH.lic file contains incorrect information or you have reached the max & licenses may not have been returned or something else.
Has anything changed recently with the licensing itself when did this behavior begin? Is there a new license file? Or an upgrade of the license manager? Did you make any change to the licensing to trigger the problem?
You can generate a new license file:
Then, configure the NLM again:
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Darin.Green
@Anonymous
@natasha.l is correct. All of your licenses are currently being used. You need to ask someone to get out of the software to allow you to get a license.
In addition, make sure users aren't launching multiple versions of the software (i.e. 2018 & 2016) at the same time.
If this information was helpful, please consider using the Accept Solution
