Flame 2021 student version installation issue
Message 1 of 25
hi,
    I'm trying to install flame 2021 student version. As i'm a student, i'd installed 2018 student version few times back. Now i wanted to use new flame student version. I've downloaded it with keys. Now i'm facing issues in installation and running the software as well. I've done multiple attempt to install it.
I'm using imac 2017, os is high sierra.
   I'm trying to reinstall it again and again but i don't find any solution. Deleted all files from many places as well.
  Is there any solution?
Replies (24)
Message 2 of 25
yann.laforest
Hi @Anonymous,
Can you please describe the problems you are encountering?
Does the application install but cannot be launched?
Best,
Yann
Yann Laforest
Principal Data Scientist Autodesk AEC
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Message 3 of 25
hi,
   After trying multiple times. Flame 2021 couldn't run so i removed it and installed flame 2018.3 on my imac. It was installed properly, but couldn't run and started to give this error "application cannot start, /opt/Autodesk and/usr/discreet. So i disabled both of these by running commands.
  Now i'm getting error "Application exited abnormally". Is there any solution of this?
Message 4 of 25
yann.laforest
Thanks.
The first thing to try is to perform a fresh install of the application.
Please, beware that performing the steps below will remove the existing Flame projects on the workstation.
  1. Uninstall the application(s)
  2. Delete the /opt/Autodesk and /usr/discreet directory
  3. Run 'pkgutil' command to remove Autodesk 'com' packages from a terminal: sudo pkgutil --pkgs | grep -i autodesk | xargs -n1 pkgutil --forget (you need to type the admin password in the terminal after running this command)
  4. Install the application(s)
Let us know if the problem persists after performing those steps.
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 5 of 25
hi,
   i've followed your steps. It was successfully done. I made fresh installation. Now when i try to open, software doesn't launch.
Message 6 of 25
yann.laforest
Thanks @Anonymous.
Can you provide the app and shell log files located under /opt/Autodesk/log?
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 7 of 25
hi,
   opt/autodesk/log. this folder is empty
Message 8 of 25
yann.laforest
Thanks for confirming.
It means that Flame does not go beyond licensing in this case.  Hence, I suspect that the problem is related to the license.
I suggest contacting the Educational Customer Support team to get assistance here.
https://www.autodesk.com/education/support/edu-contact-us-form
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 9 of 25
hi,
    i'm facing similar issue
Message 10 of 25
yann.laforest
Hi @Anonymous,
The Uninstall cannot be launched likely because it is no longer available on the station.  It might have been deleted - removed manually in this case.
In this case, you can bypass the step #1 and go directly to step #2.
Best,
Yann
Yann Laforest
10 rue Duke Street
Message 11 of 25
hi,
    I'll try to do this.
Message 12 of 25
hi,
    i'd contacted Customer Support team. Got reply from Jeffrey Ramirez. So now problem is solved.
Steps i followed,
Remove '.install' files.
  1. sudo rm -rf /opt/Autodesk/.installDeps
  2. sudo rm -rf /opt/Autodesk/.installResume
 2, Run 'pkgutil' command to remove Autodesk 'com' packages
              sudo pkgutil --pkgs | grep -i autodesk | sudo xargs -L1 pkgutil --forget
3, Removed all installed files manually
    autodesk from application,
    opt folder
4, Installed Flame again.
It is working fine now. Activated license also.
Thank you so much for your support
Message 13 of 25
hi,
   I'm getting new error that if flame crashes while importing any old projects or gets any errors in compositing. Flame just crashes. When i open flame again, it creates new workspace. So there confusion of multiple workspace. When i open any one, flame doesn't start. So next time i tried to open other workspace but still didn't happened. This goes on and on.
   I'm not able to open any projects because of this error.
Message 14 of 25
yann.laforest
Hi @Anonymous,
Can you please share the app and shell log files located under /opt/Autodesk/log?
Yann
Yann Laforest
10 rue Duke Street
Message 15 of 25
hi,
   I've attached latest log file. plz check.
Message 16 of 25
yann.laforest
Thanks @Anonymous,
This is not the logs I am looking for.
Can you please share the app and shell log files?
Example:
flame2021_app.log
Yann
Yann Laforest
10 rue Duke Street
Message 17 of 25
hi,
   sorry for the wrong file. I'm using Flame 2021 student version. I've attached a zip file of both logs.
Message 18 of 25
yann.laforest
Thanks @Anonymous .
The shell log is abnormally massive (more than 800MB), while its size should be a few KB.
It makes it impossible to read in a text reader.
I suspect that some repeated lines are bloating the log file until the application crashes.
Can you please try to launch the application, create a new project, exit the app, and share the new log files?
We might be able to identify what is bloating the log file with this new log.
Yann
Yann Laforest
10 rue Duke Street
Message 19 of 25
hi,
   I've attached new log files. Plz check
Message 20 of 25
yann.laforest
Hi @Anonymous,
The problem seems to be related to the fact that Flame tries to access a framestore that is not reachable.
Jul 18 19:42:07 : Cannot send to destination framestore ID: 111: Failed to find framestore id while establishing a connection to 111.
Jul 18 19:42:07 : Could not get file system info for host 111 partition 7: Connection refused.
Can the projects be opened in the Flame version(s) in which they have been created?  If so, the easiest solution would likely be to archive them and restore the archives in 2021.
Let me know,
Best,
Yann
Yann Laforest
10 rue Duke Street
