File3D plugin installation problems
Hi everone! I'm trying install the plugin File3D (http://johanneskopf.de/publications/solid/, download link is at the right bottom of the page), but it does not work. I created a folder called 'File3D' in the plug-ins folder containing three folders called 'plug-ins', 'scripts' and 'icons' and put the files in those folders. But when I try to load the plug-in in the plug-in manager, Maya gives an error because it cannot 'dynamically load' the plugin. Does anyone know how to solve this? Thanks in advance
_sebastian_f
because the latest version supported by the plugin is maya 8.5 .
Thank you for the quick reply. Do you know any method to make the plug-in/code work anyways? Or do you know if we can still download Maya 8.5?
_sebastian_f
i think your only chance will be to contact the author. i´m not a programmer but i guess without the sourcecode you can´t do anything to make it work in newer versions. getting maya 8.5...i don´t think it´s possible anymore but you can try contacting the support.
Thank you for the answer again. I tried to contact the support, but the message showed up in this forum again. Could you advice me on how to contact the support?
