Fatal Error on opening AutoCAD LT: Unhandled Access Violation Reading 0x24b55e28 Exception at DDDA04F5h
jubyre
jubyre
pendean
Community Legend
Community Legend
paullimapa
Questions
1) Was it running fine before?  What changed to cause this?
2) What LT version?
3) What’s your Window OS?
Paul Li
IT Specialist
@The Office
jubyre
1. Yes, The program had no problems until this happened. I figured out what was the last thing I did before this to cause this behaviour. It was a Windows 11 24 h2 update. Later I also updated the latest updates from Autocad Access. However, it did not resolve this
2. I am using AutoCAD LT 2022
3. Windows 11.  A forced upgrade from Windows 10
jubyre
I found a solution to this problem, I reset the program to default from the start menu AutoCAD items. I am Happy this is resolved now.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
The above link shows you how to do it. I hope this helps others who encounter a similar problem.
Thank you all
jubyre
Reset to default is one of the solutions listed in your link. Thank you. This resolves the issue.
