Fatal Error and "Problem loading acadres.dll resource file."
I am a univeristy student, so I can have a free version of autoCAD for 3 years. Using my university email, I downloaded the 64-bit version of autoCAD 2016 for Windows. I am running 64-bit version of Windows 10. After installing the product, i get a message that says "Problem loading acadres.dll resource file." and after pressing ok, it says: "FATAL ERROR...". I found many posts on this and other forums suggesting to reinstall autoCAD after deleting all the Microsoft c++ redistributables, disabling antivirus, disabling hardware acceleration.. I tried to download the autocad 2016 SP1, but it says that it was already updated.. NONE of these solutions worked. I am pretty desperate by now, it's the 4th time i have reinstalled autoCAD without success. I installed the 30 day trial version of autoCAD 2016 on a friend of mine's computer, running 64-bit of Windows, and found the "acadres.dll" in the "en-US" folder, in the installation directory. I noticed that it was completely missing on my computer, together with many other dll files in the "en-US" subfolder. How is this possible? I tried copying over these files, and the initial splash screen appears, but than it gets stuck while trying to load the main interface, without giving any errors. I installed autoCAD not on my main disk C, but on a different partition: i don't think this should be a problem either.
What can i do?
thanks in advance,
Camilla
Otto
Hello camilla.vespa and welcome to the Autodesk community!
It looks like you're seeing a Fatal Error while opening AutoCAD. Fatal errors often indicate program corruption or a corruption somewhere within the operating system. The following article(s) should help you resolve the problem:
Preparing your System for Installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
As i have specified in my message, i have already tried the solutions given in those links, and i have provided many details on my issues. Do you have anything more specific to reccomend?
Camilla
rkmcswain
FYI @Anonymous --- the @Otto person is a robot. It won't read your reply nor will it reply again. Don't pay too much attention to it.
So you say ----> "I found many posts on this and other forums suggesting to reinstall autoCAD after deleting all the Microsoft c++ redistributables, disabling antivirus, disabling hardware acceleration.."
Are you saying that you have done this?
Yes, i tried all those solutions, but none worked.
I actually just found a “solution/workaround” to the problem: my computer has an italian version of Windows 10. Since i noticed that acadres.dll was missing in the “en-US” folder, i thought that maybe installing the italian version would fix the problem. I uninstalled the english non-working program, and reinstalled the italian version of autocad, and it worked! I noticed that this installation created an additional folder “it-IT”, that wasn’t there in the english version, that contained this “acadres.dll”. I actually would like to have the english version instead, since most tutorials/lessons are relative to the english version. Do you believe this is a bug in the Autocad Installer? If you know a solution to this problem i would like to try it.
Once again, thank you very much,
Camilla
