Error when Installing AutoCAD 2015: 1402 Error
Hi Guys,
I'm upgrading AutoCAD to 2015 from 2013 for a client
Whilst compelting process 10/18 i receive this error
Error 1402. Could not open key: HKEY_LOCAL_MACHINE32\Software\Classes\Interface\{BEF6E003-A874-101A-8BBA-00AA00300CAB}\ProxyStubClsid
Now before you send me off to articles I have checked permissions for that key and assigned given full owner ship for that key to the user. I have even logged in as Administrator to try and install which has not worked.
So what I did to try troubleshoot further was to rename that specific key which I did ... and still got the same Error! Weird because that key does not exsist.
I than began to read the error further more slowly and realised that it actaully says "HKEY_LOCAL_MACHINE32" which does not exist in the registry tree.
Running 64Bit Windows!
Thank you.
-EDIT-
Found this, has nothing to do with AutoCAD but more an installer issue
http://www.orbis-software.com/knowledge-base/viewArticle.php?id=21
pendean
Community Legend
Community Legend
Autodesk posted this: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
64bit Windows doesn't tell anyone anything: is that still XP? Vista? 7? 8? 8,1?
Using Windows 7 64Bit
AutoCAD 2013 is also Installed on the System
As I stated above, I have gone through all articles relating to registry permissions.
pendean
Community Legend
Community Legend
Test more: log into Windows as a new user (with admin rights), does the problem go away?
1) Tried to install using 3-4 different users with Full Admin rights.
2) Cleared TEMP directory
3) Ensured UAC is turned OFF
4) Copied DVD to LOCAL Drive to install but failed
I and a group of students had the same problem. We've been googling but no success. Does anybody have a hint on this issue?
Ricardo Gonçalves.
Hi
I'm having the same problem.  Did you find a solution?  I have also tried all the options described in the links provided in this thread. Is there a connection with the 32bit registry key vs 64 bit windows?
Holding thumbs!
@Anonymous wrote:
Hi Guys,
Thank you.
-EDIT-
