Error 404 during activation
Faço parte de uma instituição de ensino superior, com isso baixei a versão do software educacional para uso nos laboratórios de engenharia. Porém sempre que tento fazer a ativação aparece o erro 404, está em anexo. Gostaria de saber uma possível solução para resolução desse problema. Lembrando que quando baixei recebi uma licença que estava descrito que poderia ser instalado em 1250 máquinas, porém como já dito acima, não consigo ativar em nenhuma.
Estou com o mesmo problema, conseguiu resolver?
natasha.l
@Anonymous wrote:
Google Translate
I am part of an institution of higher education, with this I downloaded the version of the educational software for use in the engineering laboratories. However whenever I try to activate the error 404 appears, it is attached. I'd like to know a possible solution to this problem. Remembering that when I downloaded I received a license that was described that could be installed on 1250 machines, but as I said above, I can not activate on any.
Hello @Anonymous,
Welcome.
Thank you for posting. I have translated your post for you this is an English forum, please translate your posts for better feedback in the future.
You may have reached the limit of activations or the computer name is not being accepted. Please take a look at this >article < to try an offline activation with an activation code for your edu license.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Please let us know if you have activated your educational licenses using a manual activation.
If you are having an issue regarding the activation limit, please reach out to the educational support team for further support.
