Error 1603
Error 1603
Message 1 of 17
Error 1603
Hi! I'm at my wits end.
I'm a student trying to install AutoCAD 2020 on my laptop. I had already successfully installed it on my PC. As I understand it, I can install it on up to 2 devices.
I keep getting error 1603 and I've already tried:
- turning off anti virus
- clearing temp folders
- ccleaner
- disk cleanup
- turning off firewalls (anti virus & windows defender)
- installing using Autodesk App
- installing via the download now method
- multiple restarts
And I always get to 5 out of 14 during install but it always rolls back to 6/14 then 7/14 then hangs there then stops.
I also tried AIDA but I don't think it's working?
If anybody could help, please do.
Replies (16)
Message 2 of 17
If it helps, I finally found the installation log...
Message 3 of 17
GrantsPirate
This worked for me.  Find the C:\autodesk folder and rename it or delete it.   Now try installing again.  HTh
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 17
I'll try this tonight. Thanks.
Message 5 of 17
This didn't work for me. Any other possible fixes? Microsoft Fixit cannot identify the problem either.
Message 6 of 17
UPDATE:
I followed these steps: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
And I also ran as an admin on cmd "sfc /scannow", rebooted and tried to reinstall. I even uninstalled my antivirus software (Avast & Malwarebytes) and the installation still failed...
Message 7 of 17
GrantsPirate
Sorry to hear that it didnt work.  Also see.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-Install-error-1603...
GrantsPirate
EXPERT ELITE MEMBER
Message 8 of 17
This finally worked for me!
If the above doesn't help and the product installation still fails, setup Autodesk Desktop Licensing Service to start from local system account.
  1. Type services.msc in Windows Search and hit Enter key.
  2. In Services console locate Autodesk Desktop Licensing Service and double-click on it.
  3. Under General tab, click Stop to stop the service .
  4. Under Log On tab, below Log on as: select Local System account, and hit OK.
  5. Go back to General tab and click Start to start the service.
  6. Try Autodesk 2020 version product installation again.
Message 9 of 17
i have the same problem every time when i'm trying to download it but its came to me like error 1603 .i did it like 2 times and the same problem comes to me how i can download it btw i'm a student .
Message 10 of 17
did you try the solutions provided already?
Message 11 of 17
pendean
Community Legend
Community Legend
Message 12 of 17
Hi I have the same Failure while installing Revit 2020, 2021, 3DS max 2020 and I really tried everything.
Can you see the Problem in my Logfile ?
Message 13 of 17
eng.hetory
Community Visitor
Community Visitor
THANK YOU. THAT WORKS.
Message 14 of 17
sung.jim
Just want to comment that until I switched the "Log on as" for "Autodesk Desktop Licensing Service" from "This account" to "Local System account", nothing worked.  Thanks, @Anonymous.
Maybe I missed it, but I combed through all the .log in %LOCALAPPDATA%\{Temp,Autodesk\ODIS}, and didn't see any hint of this being the problem.
As an aside, a lot of the .log or .LOG files in %LOCALAPPDATA%\Temp are in UTF-16, so I had to use "iconv" for "less".
I enabled the MSI*.LOG through the "regedit" method.  There is no "Logging" in "gpedit".  It worked for a while, then it stopped working.  I don't know why.  Autodesk's .msi cannot be invoked with "msiexec", so I couldn't use the "/l*vx" option to try to figure out what went wrong.
Message 15 of 17
sung.jim
Sorry, I forgot to mention that my problem was with Revit LT 2023, but I tried 2022 and 2021 also.  Fusion 360 does not have this problem.
Message 16 of 17
ttrevorevans
Community Visitor
Community Visitor
I have been having the same error 1603 problem when trying to install AutoCAD 2027 and have tried the advice mentioned above and it does not work.
Message 17 of 17
pendean
Community Legend
Community Legend
You'll need to share a screenshot of the actual error pop-up you receive, plus a copy of your installation LOG file the program created for you (it's in your Windows login TEMP folder), and confirm if you've engaged your I.T. person yet to help and if your login is at the local admin or hire level on your PC/Laptop.
