error [-15.570.36]. Unable to connect to licence server
Hi All,
Iam on a Mac OSX 10.12 using Autocad 2016. Our licence is on a server, which when offsite we need to use VPN to connect back to. When on site I have no issues, the issue occurs offsite.
The error Iam getting is "A valid licence could not be obtained by the network licence manager. Error [-15.570.36]"
Searching through knowledge articles I can not seem to find anything that relates to my particular error.
Any help would be appreciated
Otto
Hello aidan.dauphin
It looks like you are seeing "Error 15" when registering and activating software or using the Portable License Utility. The following article(s) should help you resolve the problem:
Port numbers for single server FLEXlm setup
Problems registering and activating software or using the Portable License Utility
Checklist for troubleshooting Activation and Licensing issues
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community..
Usually this indicates (since you're remote and it works while in the office) its timing out and you just add the system variable as indicated in this article.  However I'm not a MAC user/expert and I don't know if this is even possible.
Mark Lancaster
natasha.l
Hello @Anonymous,
Sorry for the inconvenience it seems you are experiencing difficulty pulling licensing from the network server. We first should verify connectivity to the server from the computer(s) as described below:
Using Internet Explorer to check if the ports used for licensing are open
If you have a firewall between the license server(s) and the client computers, you need to open some TCP/IP ports on the server for license-related communication. Open port 2080 for adskflex, and open ports 27000 through 27009 for lmgrd.
Configuring the Network License Manager on Mac OS X
Let me know if the above steps helped resolve the issue. Thank you.
Thank you everyone for your suggestions. We have found it may actually be a issue with our Network when using VPN. Maybe related to IPV4 IPV6
natasha.l
Hello @Anonymous,
I understand you are encountering issues connecting to the license server. I have listed some helpful suggestions to try:
- Disabling IPV4
- When re-installing the product and when prompted for a  Host ID or Server ID, try the IP address instead
- Add the IP address and hostname to the hosts file
Please let us know how it goes.
