Error 0xc000007b while starting AutoCad 2017
Instale el Autocad 2017 x64 y me sale este error (0xc000007b) como puedo solucionarlo estoy horas que buscando una solución y ninguna me resulta
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This error appears while installing or after its installed while launching the application?
Is this a fatal error?
What is your operating system?
Mark Lancaster
hello, this problem arise when i start civil3d 2018, i've windows ultimate sp1 x64. how can i solve this problem ?
@Mark.Lancaster wrote:
@Anonymous
Wow, your suggestion solved my problem. Thanks a lot!!!
You wouldnt happen to have a solution for the same error with 3DSMax 2019?
try
1. Uninstall Visual C ++, in all its versions.
2. Download and install the latest version of Microsoft Visual C ++: https://support.microsoft.com/en-ph/help/2977003/the-latest-supported-visual-c-downloads
or (if you have not tried)
https://forums.autodesk.com/t5/installation-licensing/0xc000007b-error-when-running-3ds-max/td-p/380...
BOL,
