DWG True View won't open
Message 1 of 13
Hi, I have just installed true view and it won't open.  It just stays on the screen attached all day. I have tried re-installing it with no joy.  Thanks for your help. Ross
Replies (12)
Message 2 of 13
Darin.Green
Kill any running instances of Trueview. Then perform the following:
  1. Browse to and delete C:\Users\<username>\AppData\Local\Autodesk\DWG TrueView 2017 - English
  2. Also delete C:\Users\<username>\AppData\Roaming\Autodesk\DWG TrueView 2017 - English
  3. Open the registry editor and navigate to HKEY_CURRENT_USER\SOFTWARE\Autodesk\DWG TrueView  and delete it.
  4. Start TrueView again.
This will reset your Trueview Profile to defaults.
If this information was helpful, please consider using the Accept Solution
Message 3 of 13
Thanks for your reply.  I can't find any autodesk folders in local or roaming folders.
Ross
Message 4 of 13
Darin.Green
Ok. What about the registry key?
In addition, try right-clicking the desktop icon, and choose properties. Once there, go to the Compatibility tab and enable Compatibility Mode then use the dropdown and choose Windows 7 or Vista SP1
Message 5 of 13
Hi, I tried that and still the same.
Ross
Message 6 of 13
Darin.Green
Send me a screenshot of your Right-Click Menu when right-clicking the shortcut on the desktop.
Message 7 of 13
Message 8 of 13
Darin.Green
Thanks for sending the screenshot via PM.
Why do you need 2014? Please download and install the latest version from here:
http://www.autodesk.com/products/dwg/viewers#
Message 9 of 13
Unfortunately this is the only version available on our company software centre and all external downloads are blocked. I'll try our IT people again, thanks
Message 10 of 13
Hi, I finally got the new version downloaded, thanks for your help.  Its working fine but I just have a question.  Can I change the background to white and the drawings to black to be the same as the older version?  I use a snipping tool to copy drawings and don't want to be copying all the black background.
Message 11 of 13
Mark.Lancaster
@Anonymous
At the big "D" icon in the upper left is the application menu.  Select the down arrow next to it and you should see at the bottom of the menu is a button called OPTIONS.
When the OPTIONS dialog appears, select the Display tab and in the middle of that dialog there will be a button called COLORS.  From there you can assign colors to the related elements.
Mark Lancaster
Message 12 of 13
Darin.Green
@Mark.Lancaster is correct. The options area is identical to AutoCAD options with fewer tabs.
NOTE: Options is not shown under the application menu unless you have a document opened.
Message 13 of 13
shouserCFHTQ
Community Visitor
Community Visitor
Can someone help me with this fatal error
Problem Loading ACBRAND.RES,dll
I was able to open it and use it last week.
