During installing Infrastructure Design Suite Standard 2016 file not found
AutoDesk Infrastructure Design Suite Standard 2016
Error Source file not found.
C:\Users\sbaker\Downloads\Autodesk\Autodesk_Infrastructure\x64\acadmap\Common Files\Autodesk Shared\GIS\ImportExport\10.0\plugins\zorba\share\com\zorba-xq\modules\store\data-structures\unordered-map_2.0.xq
There is no file by the name unordered-map_2.0.xq,  but there is a file  name unordered-map.xq
Steve
sureshchotrani
Try to extract the setup files again & then install.
Hope this works:)
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
