Download
Download
Download
Started download of Revit 2017 trial and power knocked out in neighborhood at about 15% into download. When power is restored should I start over?
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Not working. Did the virtual site and re-install. Said all is installed but won't open - get the hourglass. Should I uninstall everything and start over?
Mick Wilkinson
Darin.Green
No, when you double-click the shortcut, do you get the splash screen?
Update your graphics card driver from the vendors site and try launching the application again.
