Download Autodesk Navisworks NWC File Export Utility, links not working
fpensa
Message 1 of 8
fpensa
With the exception of the 2021 version, download links in the webpage "Download Autodesk Navisworks NWC File Export Utility" aren't working... I need the 2019 version
https://www.autodesk.ca/en/products/navisworks/autodesk-navisworks-nwc-export-utility?plc=NAVSIM&term=1-YEAR&support=ADVANCED&quantity=1
@fpensa - This reply has been edited by the moderation team as the legacy links were no longer valid
Replies (7)
Message 2 of 8
jrobrador19
Hi there,
I reached out to Autodesk Support, because I also cannot download from the website. I was advised to use a different browser. I'm currently using the new Microsoft Edge which is also chromium based like Google Chrome. So I tried to download using my Internet Explorer and it works!
Kudos to Autodesk Live Chat support.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
Message 3 of 8
fpensa
nope, 2019 did not work with Explorer either
Message 4 of 8
jrobrador19
Try this link: https://efulfillment.autodesk.com/NetSWDLD/2019/PLC0000012/652E49E4-E42A-4629-8012-ED929DB85C88/SFX/...
Try using this link on other browsers like Firefox or Safari. You can also try to clear the cookies and cached files of your local browser then try again.
I hope this helps.
Jerous Obrador
Message 5 of 8
CharlesGoin
WHY is the exporter not BUILT INTO REVIT !
Seriously Autodesk..
Message 6 of 8
pendean
Community Legend
Community Legend
No one here is Autodesk Revit team, but you can ask Autodesk over there, that forum exists right there just so you could ask/tell Autodesk whatever you want https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Message 7 of 8
pascal_djoumo-gadjou_1
Community Visitor
Community Visitor
i need the 2024 version
Message 8 of 8
pendean
Community Legend
Community Legend
