DirectX Runtime Failed Failure is ignored, Result=1619
I am trying to install Autocad 2018 after my previous 2016 version failed to run.
But "DirectX Runtime Failed Failure is ignored, Result=1619" failure appears.
Please! How can I solve it? I've not found clear solution to this problem, especially because I'm not tech expert.
Otto
Hello icardonaXN6KL and welcome to the Autodesk community!
It looks like you are looking for information related to the error: "DirectX® Runtime Failed Failure is ignored, Result=1619". Community members with similar questions found the following article(s) useful:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent
AutoCAD 2013 Suite failed installation aborted, result=1603
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
