Convert from BDSP to AEC Desktop
SteveFong
Message 1 of 14
SteveFong
We have a number of BDSP installations.  We have recently acquired several AEC desktop licenses.  Some of my users would like to convert from a BDSP to an AEC license because of the additional software in the AEC license.
Has anyone determined how to convert these licenses, or is my only option to uninstall all BDSP software and reinstall the same software as the AEC license?
Replies (13)
Message 2 of 14
Otto
Hello SteveFong
It looks like you need help uninstalling - or have issues that may be addressed by uninstalling - an Autodesk product. Community members with similar questions found the following article(s) useful: The following article(s) should help you resolve the problem:
Uninstalling a Product
Once your product is uninstalled, please try downloading your Autodesk Software using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 14
Mark.Lancaster
@SteveFong
If the additional AEC Collection applications are currently not in the AEC collection in the suite than yes you would need to install those individual products.   If your current suites are based on 2017 and term based then all you need to do is a license reset.  If the suites are based on perpetual license then no you can't switch which means you would have to uninstall it.   But I will tag my buddy @Darin.Green for his input and he should give you a rock solid answer..  Smiley Wink
Mark Lancaster
Message 4 of 14
SteveFong
Mark,
Thanks for the reply.  Our BDSP licenses are not network based and we pay yearly for the subscription, so I believe they are indeed perpetual.  I can imagine that there are a lot of users that will be switching from one licensing structure to another, so I would hope that Autodesk would put out a tool to help with this.  Not having to uninstall/reinstall Revit and Autocad on lots of machines would be a very good thing.
Message 5 of 14
natasha.l
Hello @Mark.Lancaster,
These instructions apply to 2017 product. If you are dealing with older versions you will have to uninstall and reinstall the products for the collection or if you have activation issues.
For the products in the collection you can reset the licensing so when you launch the products you can activate them with your new collection credentials/information.
License Reset for 2017 products & up:
    1. Close your Autodesk program.
    2. Delete the three (3) files prefixed with Adskflex  from the following folder:
      C:\ProgramData\FLEXnet\
      Note: The above files are Hidden files. You may need to enable Show Hidden Files in Folder options.
    3. Locate the following folder:
      C:\User\username\AppData\Roaming\Autodesk\ADUT
    4. Rename this folder to: ADUT2
    5. Browse to the following folder:
      C:\ProgramData\Autodesk\CLM\LGS\<product key>_<product version>
    6. In this folder, do one of the following:
    • Open the LGS.DATA file, change the value to _USER OR _STANDALONE , and save the file.
      or
    • Delete the contents of the folder.
  1. When you launch your Autodesk software, you will be logged in automatically, you will be prompted to log in or you input your Serial Number & Product key.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Message 6 of 14
SteveFong
Natasha,
Thanks for your input.  I will give it a try!
Steve
Message 7 of 14
SteveFong
Natasha,
On machines that only have the BDSP applications installed, under the folder "C:\ProgramData\Autodesk\CLM\LGS," only the 765I1_2017.0.0.F folder exists; which is the "Autodesk Building Design Suite Premium 2017" folder.  There are no license folders for each software.  This indicates to me that individual softwares do not have their own license codes when installed as part of the BDSP.  As such, I suspect that I cannot reset the license code.
Is this correct?
Steve
Message 8 of 14
Darin.Green
@SteveFong
You can only accomplish this with NETWORK licenses... Since you have Standalone seats of BDSP, you'll need to uninstall and install each application independently that the user want access to. For example, if the user need Revit, Civil 3D, & Navisworks then you'll need to download and install them 1 by 1 using the individual product keys for each.
i.e. AutoCAD product key would be 001I1 for 2017 and 001J1 for 2018...
Why, you asked? Because the standalone applications on those machines are installed with the BDSP Product Key and BDS does not cascade into Collections. Therefore the collection license doesn't understand or know what application to license.
So the answer to your question is No, you cannot reset the license nor convert the applications for collections. You'll need to uninstall the entire suite and install the products individually. Use the following link to find the right product keys:
2018: Product keys for Autodesk products
2017: Product keys for Autodesk products
If this information was helpful, please consider using the Accept Solution
Message 9 of 14
SteveFong
Thanks for the info.
I suspect as Autodesk forces us into the Desktop collections that lots of people will have this question.
Steve
Message 10 of 14
diatecadmin
I thought that you could just reset the license by deleting the adut file  in products 2017 and above
Message 11 of 14
Mark.Lancaster
@diatecadmin
If you have a standalone license of your suit you can't switch it to AEC subscription.  This only works if you have a network license of your suite.  If its standalone you have to uninstall the suite and install the product of the AEC Collection that you need.
Mark Lancaster
Message 12 of 14
diatecadmin
Thanks Mark.
That clears it up. I understand now
Message 13 of 14
SteveFong
GMG,
It turns out that the solution that Natasha recommended does not work for BDSP "non-networked" installations as is referenced in Post 7.
Unfortunately the accepted "solution" is the answer that shows that there is no solution.   Apparently uninstall / reinstall of all applications is the only true solution.
Steve
Message 14 of 14
natasha.l
Hello @SteveFong
In some cases that's just the easiest way if you can't be certain how your products were installed, Making the switch from Suite to Collection. A installation from a deployment will have a ProductInformation.pit file  it will store your previous activation information not allowing you to re-activate with your IC credentials.
Thank you for returning to let us know what worked for you.
