AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Communication Failure Error with installation
Message 1 of 156
I've been getting an error when tgrying to use "Install Now" option on Maya 2013. I've take a screenshot of it. Could anyone tell me what to do? I'm pretty green when it comes to network erorrs or any kind...
http://oi46.tinypic.com/30cbnrn.jpg
Thank you!
I hope this is the right place to ask. Google brought me here when I tried to google a solution to this problem, but I found none.
Accepted solutions (4)
Replies (155)
Message 101 of 156
jessica.t
Hi @Anonymous and welcome to the Autodesk Community!
Have you tried changing your download method? If you try that and the problem persists please try these steps to help fix the issue:
  • In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
  • In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
  • Turn off your personal firewall or VPN, if you use one.
  • Disable UAC
  • Close and reopen your preferred browser.
  • Re-download from the Virtual Agent
Please reply to this post with any other questions or concerns. Thanks!
Jessica Thrasher
Message 102 of 156
When I try to get maya, I get this error when using the Install Now option:
http://prntscr.com/490cyc
I'm not really sure how to fix this
Message 103 of 156
I got newest .NET framework, I opened ports 80 and 443 in my firewall.
Now i try to directly install Inventor 2015 - i get connection failure, download - too. I even try to browser download it - 3 times it stopped at 2GB and didnt want to go further. What else can I do ?
Message 104 of 156
philip.s
Hello @Anonymous!
Outside of the recommendations listed on the Communication Failure warning screen, were you able to try Jessica's suggestions from the above post (also copied here for your convenience)? The simplest workaround is typically to utilize a different download method, specifically Browser Download, which can also be accessed from the Autodesk Virtual Agent.
  • Disable UAC
Message 105 of 156
I am a student and downloaded Maya student's version but have error keep showing "Communication Failure Error with installation".
please see attached print-screen Maya_Communication Failure Error with installation.jpgand tell me what to do. Thanks,
Josephat
Message 106 of 156
Hi Philip, I have sent you question about downloaded student's copy that resulted Communication Failure during installation. Also sent you print-screen. Please confirm. Thanks, Josephat
Message 107 of 156
philip.s
Hello Josephat,
Did you try the suggestions that mentioned in the above postings?
  • Disable UAC
Message 108 of 156
Hi Philip,
I have Disable UAC and delete cookies, temporary internet files, and history. Then downloaded Autodesk Maya 1.8GB file size, the above result is all I got.
Please instruct me further. Thanks!
Message 109 of 156
philip.s
Hi Kenny,
It looks like you haven't download pt.2 yet which is why you are receiving the missing file error. You can do so via the Autodesk Virtual Agent linked here.
Please let us know if that works!
Message 110 of 156
I've downloaded the pt.2 and same error on the previous print-screen occured.
Please advise where to move the pt.2 before installation or which of pt.1 and pt.2 do I install first.
My OS is Win 7 64Bit and not Mac
Message 111 of 156
camilo.lemos
Hi @Anonymous ,
Please, download both parts from the Virtual Agent. Once fully downloaded, double-click on Part 1 and the installation should proceed normally.
Make sure your firewall and anti-virus programs are disabled during the download.
I hope this helps!
Camilo Lemos
Message 112 of 156
Hi Camilo,
I have carried your task but didn't work. I had online chat Norton which they tried their best but detected that "ntxpiinst.exe" is affected. Told me to contact Autodesk and in form them that the installation file have virus ntxpiinst.exe. As Norton has detected this file as a threat you (me) can contact Autodesk MAya and let them know that Norton has detected a threat about Autodesk MAya file.
Message 113 of 156
camilo.lemos
Hi @Anonymous
I will forward this to the Maya team.
Thanks for letting us know.
Camilo Lemos
Message 114 of 156
Hi Camilo,
I am still waiting to hear from you regarding the affected files and reply from Maya team as you said.
I can forward you more print-screen if you give me email address or I can sent it here if you want.
Message 115 of 156
jessica.t
Hi @Anonymous,
I've just emailed Camilo with your request, you'll likely hear from him tomorrow when he's back in the office. Thanks for your patience!
Jessica Thrasher
Message 116 of 156
camilo.lemos
Hi @Anonymous
I've checked with the Maya team and this file is part of the common Autodesk installer, this is not a virus, you can go ahead and download the product normally.
I hope this helps!
Camilo Lemos
Message 117 of 156
Yes Camilo,
I have been able to install Maya Pt.1 in my computer - up running.
Please confirm if Maya Pt.2 still needed to be installed because after insighting the key [OK] to the next step but the <Install> button not active as I hover my mouse over. See attached.
Thanks very much!
Message 118 of 156
hello, new and im been trying to download this for school student version
i did the whole port thing, and then turned off my windows smartscreen, and and i got it to go, but  as it asks me where to put it i hit ok and then i get this.
http://gyazo.com/5da7355f8d358de8a8525eab42f09188
not sure what im doing wrong? for it to do that.
Message 119 of 156
I do have similar error from the begining until I seek help from the autodesk experts, I was able to get it right.
NOW delete all the download files and start afresh by downloading from Virtual Agent and start new download on the link provided.
NOTE: This instruction is for Autodesk Maya only.
Make sure you download both two files Part.1 and Part.2
When you finished downloading them, double click first Part.1 to resume installation and you will be prompt to create folder where to extract your files. After that Maya installation will start while you follow the steps.
Good luck
Message 120 of 156
i see that athere are two parts for maya 2015, but my class needs 2014.
Idk if i can use 2015 for my class and if it will work properly with the 2014. since thats the one we have on our school computers.
