CMD line options for installing DWG Trueview
Message 1 of 8
Is there documentation available for installing DWG TrueView 2019 via the command line?
Im interesting on installing it this way with some parameters to customise the install like not putting the shortcut on all users desktop & running it silently.
thanks
j
Replies (7)
Message 2 of 8
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
I could be wrong but I don't think the free viewers from Autodesk pay attnetion to any settings.  Meaning its install one way..
However I will tag @m_latz for input..
Mark Lancaster
Message 3 of 8
m_latz
I have not tried / looked at yet. But I suppose it is a solution available.
At the moment I download the installation packages and will check / test tomorrow.
regards
Markus
Message 4 of 8
natasha.l
Hello @Anonymous,
Here are some basic command line  Options & Parameters
Thank you for posting.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 5 of 8
m_latz
Okay just tried and it works as for TrueView 2018.
See here for further details:
https://forums.autodesk.com/t5/installation-licensing/trueview-2018-without-the-shortcut/m-p/7072062...
The transformation also works for TrueView 2019.
If you need other adjustments and you do not know how to create/modify transformations let me know.
To install silently use i.e.:
setup.exe /q /I setup.ini /language en-us
For further options for "setup.exe" see the link from Natasha.
regards
Markus
Message 6 of 8
Good info - thanks!
Is there an MSI installer available for TrueView 2019? I can only see a .exe
thanks
j
Message 7 of 8
m_latz
What you download from Autodesk is a self extracting compressed file which extracts the contents to C:\Autodesk\... (default location).
There you have a "setup.exe" file which reads the "installations instructions" from the setup.ini file in the same folder.
The TrueView 2019 installation is a msi file which you can call directly. But you need a lot of prerequisites (runtimes needed to run TrueView 2019).
This is the part of the setup.exe to check which runtime is needed and install if necessary, etc.
regards
Markus
Message 8 of 8
Hi, I am using a KACE deployment appliance to install DWG True View 2019 silently; using associated file
DWGTrueView_2019_Enu_64bit.sfx.exe
The setup extraction launches, using the following command line.  The issue I am having is that, I am prompted for the install path and other UI.
regards
Markus
regards
Markus
