Hi, I am using a KACE deployment appliance to install DWG True View 2019 silently; using associated file
DWGTrueView_2019_Enu_64bit.sfx.exe
The setup extraction launches, using the following command line. The issue I am having is that, I am prompted for the install path and other UI.
setup.exe /q /I setup.ini /language en-us
@m_latz wrote:
What you download from Autodesk is a self extracting compressed file which extracts the contents to C:\Autodesk\... (default location).
There you have a "setup.exe" file which reads the "installations instructions" from the setup.ini file in the same folder.
The TrueView 2019 installation is a msi file which you can call directly. But you need a lot of prerequisites (runtimes needed to run TrueView 2019).
This is the part of the setup.exe to check which runtime is needed and install if necessary, etc.
regards
Markus
regards
Markus
