Civil 3D 2023 - "VBA not installed" always showing up when opening a drawing
Simon_Thouin-Verdun
Simon_Thouin-Verdun
I just install Civil 3D 2023 and I always have this message when I open a file:
VBA not installed
This drawing contains content created with Microsoft Visual Basic for application software (VBA) what do you want to do?
Convert VBA content  to .NET
Download the VBA Modules
Continue with the current command
I have download and install the VBA Modules (uninstall et reinstall 2-3 times...) and the message is still there.
What can I do to fix this?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
lim.wendy
Hi Simon,
Thanks for reaching out to the forum. Autodesk has begun the transition of VB customization from VBA to .NET technology. If you have drawings created with an older version of Civil 3D (2010 version and older) and you are opening these older files in the new Civil 3D (2011 and above), the warning message will be displayed.
Click on Convert VBA content to .NET. Save the dwg, the content will be converted to .NET. See this explanation by Alfred Neswadba for more information.
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Simon_Thouin-Verdun
Thank you for your answer but I'm not sure I understand.
In the previous version of the sofware (2022, 2021, 2020...) I usually download and install the VBA Modules and after that I didn't get this message anymore.  For the 2023 version, Autodesk still make available for download the VBA Modules but when install, you still get the message and you have to convert to .net.
