Cant install Revit 2022 (License Manager is not functioning or improperly installed)
Hey Guys!
I was using Revit 2021 before this with no issue but while installing Revit 2022 I did not uninstall Revit 2021. I am unsure if that was the first mistake I made. But everytime I have reinstalled Revit 2022 it takes a bit longer than it should to open and asks me what way i want to sign in which shows me to sign in with my account and when I click for it to do so it doesn't as me for my log in info and gives me "License Manager is not functioning or improperly installed" and shuts it down. What am I doing wrong and what are the alternatives in case anything does not work.  I already uninstalled Revit 2021 and have reinstalled Revit 2022 3 times and still face the same issue. I have midreviews coming up and am incredibly stressed. Thank you so much!
RDAOU
@Anonymous
You need to follow the instrucion for a clean uninstall ... you might end up having to remove ALL autodesk products and rei stalling them
DarrenP
you can go through this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
DarrenP
