Announcements
Cannot install setup
PLEASE HELP!
When trying to install AutoCad LT I keep getting the following error and it wont let me install:
'Windoews cannot find ' setup.exe.' Make sure you have  typed the name correctly, and then try again'.
I had previously installed free trial and tried to uninstall it before downloading my subscription.
PLEASE HELP - on a deadline.
Thanks in advance - Felicity
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
There's no need to create another document just to show an image.  In your posting you can just click the photos tool (on the posting toolbar) and attach your image directly.
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
robBouch
Hello @Anonymous
Welcome to the community!
I would suggest that you download the full installer using AVA and the Browser Download method.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
robBouch
Hello @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
