Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Cannot Install Revit 2021
jmartucci2
jmartucci2
I cannot install Revit 2021 no matter what I try. I tried the Autodesk Desktop app installer, install failed. I tried the browser download, install failed. I tried removing all my temp files, installed failed. I run all the latest updates on my computer and restart multiple times, install failed. Everything I've researched and tried has been a huge waste of my time.
I got it to install a few weeks ago, but my computer immediately had an error afterward which made me restore my entire operating system back to where it was before I had installed Revit 2021. After waiting to let Autodesk figure out the issues, I tried installing again today, which has been unsuccessful. To make matters worse it seems I cannot open my projects in previous versions of Revit now.
Mark.Lancaster
@jmartucci2
Without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
jmartucci2
@Mark.Lancaster
Thanks. The install log is attached. I didn't see any results for "/SN" when I searched.
Mark.Lancaster
@jmartucci2
Need log with the word setup in it...
Mark Lancaster
jmartucci2
Here's the setup log in the google drive link. I got this error when I tried to attach to the post.
https://drive.google.com/file/d/147LDlQ5mBPDJsYBzCNuH09mHSlDFJcE9/view?usp=sharing
rouling
Autodesk Support
Autodesk Support
Hello @jmartucci2
Thanks for the logs, I had once the same issue with the 2021, What I did was a clean uninstallation by using the following Article.
Also make sure that you uninstall the Autodesk Desktop Licensing that can be found in the following folder:C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing.
After you  did the clean uninstall make sure that you are using the Browser Download method to Install Revit 2021 again.
Wish you all a nice day
Gilles Roulin
Customer Service Technical Specialis
