Cannot install AutoCAD 2019 .NET Wizard
vladop
Message 1 of 66
vladop
When I try to install the Managed .NET project wizard I get this message:
Visual Studio installer shows that .NET Framework 4.7 is installed:VS installer.png
Release value in registry is 461808, which means that .NET Framework 4.7.2 is installed:VS version.png
Any idea how to solve this?
Vladimir
Replies (65)
Message 41 of 66
DotNetWizards works ! Thanks
Loading the template, all the references work, but i have this error clicking property on the project name in the solution explorer and going on Application tab. I had the same error when loading the sample in "My first autocad plugin" (see https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/lesson-1-the...). Have you any idea ? (translation of the error message is "There was an error while loading the page. Not implemented operation or method")
Message 42 of 66
Nice! Thank you!
Message 43 of 66
nicole
Thank you very much, the screencast helped a lot!  We got it working.
There were some issues in the discussion group thread with the syntax typed in DOS, but the screencast cleared it up!  Thanks again, Nicole
Message 44 of 66
When I try run command in administrator command Promt:
C:\Temp>msiexec /i "AutoCADNetWizards.msi" TRANSFORMS=LcsMst4DotNet47-8.mst
instalation starts but after I click on button InstalNow an error occure
"Could not access network location [WindowsVolme]"
could you please help me to solve this issue ?
Message 45 of 66
nicole
Is it possible you don't have permissions to install to the volume you are working on?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
When i walked through the steps above, there was a problem with the syntax in the typed commands in DOS, but when i reviewed the video it cleared it up for me.
I hope this helps.
Best Regards,
Nicole Morris
KETIV Technologies, Inc.
Message 46 of 66
Thank you, the fix for framework 4.8 worked for me.
Message 47 of 66
Ahmed_204
Good Day ,
is there any transorm files for .net framework 4.8 update (528372) ?
Message 48 of 66
m_latz
For the .NET Wizard 2019 ?
regards
Markus
Message 49 of 66
Ahmed_204
Yes , for AutoCAD 2019 .NET Wizard
Thanks for replying
Message 50 of 66
Ahmed_204
@m_latz
HI ,
Is there any solution file for this version of framework ?
Message 51 of 66
m_latz
Hi @Ahmed_204 ,
sorry for the delay.
Extract the attached transformation file and try this:
msiexec /i AutoCADNetWizards.msi TRANSFORMS=LcsMst4DotNet47ff.mst
I have simplified the condition check and hope it works on all .NET 4.7 and above versions.
For details see previous posts.
regards
Markus
Message 52 of 66
Ahmed_204
hi @m_latz ,
Thank you for your support , i tried the new file and the attached error appeared to me after pressing enter in the installation process.
Thanks again and i hope we can solve it.
Message 53 of 66
m_latz
Have you opened the cmd window with "Administrator" rights ?
regards
Markus
Message 54 of 66
Ahmed_204
Yes
Message 55 of 66
Ahmed_204
Yes
Message 56 of 66
Ahmed_204
Hi @m_latz ,
Do you have any suggestions that we can do to solve this problem ?
Thanks for your support.
Message 57 of 66
m_latz
You should try to call the install with logging:
msiexec /i AutoCADNetWizards.msi TRANSFORMS=LcsMst4DotNet47ff.mst /L*v "C:\Temp\AcadNetWiz.log"
and upload the log file here, then I can take a look.
The log file name I used is only an example, you need a valid path.
regards
Markus
Message 58 of 66
Ahmed_204
Hi @m_latz ,
Thanks for your reply , I uploaded the log file.
Message 59 of 66
m_latz
Which Visual Studio version(s) do you have installed ?
Where is your is your %userprofile% folder ? (Which drive ?)
And do you have the folder %userprofile%\Documents\Visual Studio 2017\Templates\ProjectTemplates ?
regards
Markus
Message 60 of 66
Ahmed_204
Hi @m_latz  ,
1-I installed visual studio 2017
2-Drive (c:)
3-yes, I have
Thanks for your Support.
