Can't install autocad 2017
Hi, so I've just signed up for the student autocad download and when I go to download it it has this message "This package will run a program to determine if the software can be installed." I press continue but then it all closes and nothing happens. Anyone know how I can fix this?
maxim_k
Welcome to Autodesk Forums!
Hi Jessica,
I'd suggest you to try to use the latest version of AutoCAD 2017 for Mac installer which you can find here:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-for-...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
natasha.l
Hello @Anonymous,
This could be a security issue on your Mac, please try to adjust the settings in the Privacy & Security outlined here to continue to install.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
Dear,
I have a similar problem, yet using AutoCAD LT 2015.
Downloaded the latest release from AutoCAD websiTE. But issue remains.
For testing purposes I tried to download more recent version (2016, 2017 and 2018) as wel,  same problem.
i'm using macOS Mojave (10.14.6)
Looking forward for a possible solution.
Thank you in advance,
Kind regards
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
2015 version is not supported under this OS version.  2016 to 2018 are but you have to download and install per https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/autocad-and-mac-os-mojave-compatibility.html
Mark Lancaster
