can't get request code
mahyarSOORANI
Message 1 of 12
mahyarSOORANI
I can't offline register . because all Autodesk Software don't give me Request Code ….
I entirely disconnect from Internet but ….
Replies (11)
Message 2 of 12
mahyarSOORANI
I wanna thiiiiiiisss
Message 3 of 12
I'm not sure what steps you have taken, other than the screen-shots you attached.
Also not sure of your license type..perpetual? subscription?
Here are the (somewhat confusing) instructions for activating 2021 products >instructions<
If this doesn't help, you may want to get in touch with your re-seller, or post in the >licensing and activation forum<
Message 4 of 12
rkmcswain
@mahyarSOORANI  - that doesn't look like a valid S/N to me. Unless you edited the image for posting here.
Message 5 of 12
mahyarSOORANI
I have Perpetual Activation . I tried that way in your shared link but no effect … I disconnect from internet but I can't see Request code . I have no problem earlier but Strangly from yesterday all Autodesk software like autoCAD  3dmax  revit  v2020 and v2021  don't give me Request Code and I always confront to Last pic in previous post  at the end
Message 6 of 12
mahyarSOORANI
no this is correct … I always use this code earlier but in next page don't give me Request code … 😞
Message 7 of 12
pendean
Community Legend
Community Legend
You can try this automated page for help https://ava.autodesk.com/
Message 8 of 12
Tony_Michniewicz
Autodesk no longer supports offline activation for 2021 products and later.  This is one of the topics covered on this page: https://knowledge.autodesk.com/customer-service/download-install/activate/manual-activation-registra....  In short, you will need to connect your system to the internet in order to complete the online activation process.
Tony Michniewicz
Revit Software QA Analyst
Message 9 of 12
mdavis22569
@mahyarSOORANI
Were you able to get this resolved?
Also, you shouldn't have a serial number anymore unless you have a Network license. Also looks like the sign in option is missing.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/No-Let...
Mike Davis
Message 10 of 12
whisker_plot11
Observer
Observer
I have faced similar issue... it is not for post purpose dear
Message 11 of 12
kiril_mrti
Instructions for Finding the Request Code
  1. Follow the steps exactly as shown in the author's screenshots.
  2. Once you have completed those steps, navigate to the following directory:
    C:\ProgramData\Autodesk\AdskLicensingService\Log\
  3. Locate the file named ACD20XXen_USRegInfo.html (the file name may vary depending on your Autodesk version).
  4. Open this file, and you will find the required Request Code inside.
Message 12 of 12
mahyarSOORANI
Thanks.  Good those days
