Can I run 2 Autodesk programs at the same time?
Alex_Pendray
Message 1 of 10
Alex_Pendray
I am interested in using 2 Autodesk programs at the same time but I want to avoid breaching the terms and conditions.  I understand that using 2 different versions of a software at once is a breach of the terms and conditions (for example, running revit 2021 and 2022 concurrently).
Can I run Revit and Autocad at the same time?  What about Autocad and Autocad Architecture?
Replies (9)
Message 2 of 10
rushabhthakkar_910
@Alex_Pendray, Firstly are you talking about Educational Licenses..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 10
rushabhthakkar_910
Also, AutoCAD and AutoCAD architecture are not different.
Meaning AutoCAD Architecture Toolset is included with AutoCAD subscriptions and is not a different software.
Thanks and Regards,
Rushabh Thakkar.
Message 4 of 10
mdavis22569
What type of License do you have?
That's the most important question first ...
Mike Davis
Message 5 of 10
Alex_Pendray
I have an AEC Collection license for a single user.  Not an educational license.
Message 6 of 10
Alex_Pendray
Also, can I have 2 windows of the same software open at once?  For example, 2 instances of Revit 2022 open on the same device.
Message 7 of 10
rushabhthakkar_910
@Alex_Pendray,
(https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Industry...)
Thanks and Regards,
Rushabh Thakkar.
Message 8 of 10
rushabhthakkar_910
Yes you can.
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 10
mdavis22569
Yes I do it with Inventor all the time.
Mike Davis
Message 10 of 10
mdavis22569
They know you'll likely use more than one at a time on occasion.
Just can split it up to different users.  The collection is assigned to you ..
Mike Davis
