C3D 2020 - Product License - Out of Time
scott
scott
Within a minute or two of launching C3D 2020, I am recieving a dialogue box indicating "License checkout timed out. What do you want to do? AutoCAD will be closed down." I am offered to save and quit or quit without saving. I chatted with Autodesk but they provided the following steps which have not worked. 1) Type cmd on Start 2) Right click and Run as Admin 3) Past "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.0.1.1462\AdskLicensingService\AdskLicensingService.exe" 4) Note If the Hotfix has been installed paste "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.0.3.46\AdskLicensingService\AdskLicensingService.exe" instead. 5) Leave the cmd window in backgroud (if the windows will be closed the software will show up the error again). Would anyone have another solution? Thanks, Scott
mdavis22569
So you've done this already?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Mike Davis
scott
Thanks, Michael!
I'm not sure why the Autodesk Help Support didn't suggest this and I didn't find it. I appreciate your response.
bmoreyS2EZ2
Community Visitor
Community Visitor
because autodesk support is the worst ****ing support going.
