BIM360 & ACC - License Count
eb8248
Message 1 of 10
eb8248
How do I calculate how many licenses my Company has left?
I searched but did not see a solution. I did see a 2020 post stating that there isn't a good way to check back then. Has Autodesk given us the raw data to calculate license counts?
I definitely have not found the table where I can identify users that are bringing their own license.
Any help would be greatly appreciated!
[ The subject line of this post has been edited for clarity by @handjonathan Original: License Count ]
Replies (9)
Message 2 of 10
rushabhthakkar_910
You can monitor your current license information for each product in Autodesk Account.
  1. Sign in to your account at manage.autodesk.com.
  2. Under All Products and Services, find your product.
  3. In the product tile, click View Details.
  4. If you see License Details on the product details page, select it to display your serial number and product keys.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 10
mdavis22569
maybe share a bit more info:
What type of license?
Do you have them all assigned?
That's where I'd start
https://www.autodesk.com/support/account/admin/users/assign-access
Mike Davis
Message 4 of 10
eb8248
I am trying to deactivate users that we no longer need in ACC Build or BIM 360.  We don't have a regular purchased license setup.  I've been told by Autodesk that we have a license agreement with them.
I am trying to find the users that have actually brought over their own licenses.  I am using Power BI and the ACC Data Connector.  Do you know how I figure out what members have external licenses?
I've also noticed that when users login using the Build Plaingrid App, the Last Login Date in the database doesn't get populated.
Any information would be appreciated!
Message 5 of 10
rushabhthakkar_910
@eb8248, See if this helps you ..!!
(https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/You-want...)
Thanks and Regards,
Rushabh Thakkar.
Message 6 of 10
mdavis22569
@rushabhthakkar_910
That won't help @eb8248  if he looking for outside purchased licenses:
Do they have a network license? To use the LMTOOLS?
Mike Davis
Message 7 of 10
handjonathan
Hi @eb8248
Thanks a lot for posting your question to the forums!   As far as i know, the login info is only captured and reported when a user is logged in via the web and not a mobile device. Concerning the external users who bring their own license, im tagging @gareth.spencer1 , who is more up to speed on all this than me and can advise accordingly on reporting.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 8 of 10
gareth.spencer1
Hi @eb8248 ,
Previously in BIM 360 you could use the Account Admin Analytics dashboard to review the members and the services being used.
A few people have mentioned about network licenses, but ACC does not work with network licenses. So, you cannot report using LMTOOLS. I would suggest whoever is your Autodesk accounts manager who looks after your licenses to log into their Autodesk account and check under the user management and see which products have assigned seats.
You can use the Insights inside ACC to export out the Data Connector information to capture all the administration information such as users, projects, and much more. But I am unaware if you can report on those who bring their own subscriptions.
I have not done this myself as I don't look after out licenses but from the insights within the Autodesk account portal, you can report out information such as products and users. You can then export the information out and report using things like PowerBi to present it nicely.
I hope this helps to answer your question. @handjonathan thanks for copying me in here.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Message 9 of 10
eb8248
I exported the data into Power BI and two key data points are missing. There isn’t a field to identify external users and the last date user logged in is not captured when using the Build PlanGrid app. These are definitely a gap. I could use the transactional data to get the last login data but that would be a chore.
Thanks for trying to help me but I believe there isn’t a way to retrieve the data I need. I hope they add it soon.
Message 10 of 10
mdavis22569
There isn't an easy way ...
They are working on things for the Account Manager...
However what type of License do you have?
Mike Davis
