@RobDraw wrote:
@mchristop wrote:
Please have your Autodesk team consider applying for a "Whitelisting service account" with AVG to prevent this from happening in the future.
https://secure.avg.com/submit-sample
So, you get a response from Autodesk, which not only referred you back to the AVG software, but directed you on what to do. Basically providing support for AVG, And you still want them, instead of you, to be proactive about this?
What is this world coming to?
Yes, WHAT IS THIS WORLD COMING TO?!
I am not sure who changed the Accepted Solution for me, but that is not cool! But sadly typical for Autodesks forum!
I did NOT mark natashal84 's response as a Accepted Solution!
ABSOLUTELY, Autodesk needs to be proactive about this! We pay a LOT of money for Autodesk software. Autodesk needs to fix this problem so it doesn't inconvenience their users. Do you have any idea how much billable time was lost because of this issue?
Her response does not fix the problem. It is a work around. I am fully aware how to create an exception In AVG. I am not about to do this on 50 computers. I was happy to see an Autodesk response. Then I knew that they would see my suggestion of how to fix the problem. How does the saying go? "You can lead a horse to water but you can't make them drink."
Disabling Antivirus is NEVER the solution!
If your antivirus tells you that a file (Or two in this case, both from Autodesk) on your computer is trying to do something that it probably shouldn't do. It is probably not in your best interest to create an exception for those two files just because the creator of those two files say they are ok.
The creator of those files needs to prove that they are ok. Which is what I suggested they do.
My suggestion is the only acceptable solution. My solution would prevent this issue from happening in the first place for these updates and any future updates. And that, my friends is how you SOLVE a problem. You FIX the problem for good.
********** ACCEPTED SOLUTION START **********
The files in question are far too large for me to submit on your behalf.
********** ACCEPTED SOLUTION END **********
I can only hope that Autodesk will do the right thing and follow my advice.
