Automatic Installation using SCCM
Hi to All,
I would like to install AutoCAD 2020 with Plant 3D Object Enabler together using SCCM without prompting the user at all.
So far I have managed to use Combine and Deploy to combine the programs but it still prompts the user when installing the 3D Object Enabler. Has anyone come across this and know the way to solve it?
natasha.l
Hello @Anonymous,
AutoCAD Plant 3D (Object Enabler) is no longer installed as a separate program, subscribers will no longer have to access AutoCAD vertical functionality through separate offerings. In this case, all the same AutoCAD tools & features will be installaed along with the Plant 3D tools & features by installing the AutoCAD Plant 3D 2020.
Please review How to install silently using SCCM. & please note that after installation it will require a user to sign-in for license validation.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
