Autodesk won't let me access forums of AutoCAD
davidsemail916
davidsemail916
As soon as I log in, wether from Chrome or Safari, the browser immediately starts refreshing and logs me out.  I can't post, or view forum threads.  I FINALLY found a workaround and that is to access forums.autodesk.com via Incognito window.  Happy to finally be able to communicate with you guys again, but a more permanent fix would be great!
Also, Autocad can't validate my license and won't open.  I followed the prompts to the T and it'll work for 1 session and won't be able to authenticate my license.  I'm using AutoCAD for Mac.  Any ideas?  Anyone?
mdavis22569
Are you one a home network or your work's network?
How did you access this one?  Incognito too?
Here is a licensing tool ( I know, licensing, but it's more than that)
Can you install it
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
and review the connection tab and see if anything is blocked. Want to check your access. Might be your anti-virus or firewall is blocking sites.
Mike Davis
Simon_Weel
Is there some plugin in your browser that throws in a wrench?
bryanMJ2LS
We are having the same issue at our office. Opening the forum in Incognito mode worked! I had to take a screenshot of your reply in the moment before it started refreshing to even read your temp solution.
