Announcements
Autodesk Inventor 2016 failed download
I am running an HP Envy 15t with an i7, 250 ssd and 1tb hard drive, etc more than enough to run this program. I am running Windows 10 which may be part of the problem but many many others have succesfully donwloaded Inventor on it before. I am trying to get Inventor Proffesional 2016 from the free stuent download, i am not an expert on computers but i know how to download a program, so bear with me if i dont undertsand something. My problem is a 1603 error, low image library. I have spent hours upon hours researching and trying solutions for this, 10+ attempts to donwnload, but i have come up with nothing but frustration and of course no direct help from AutoDesk. Anyways, any and all suggestions or solutions would be greatly appreciated. I need the program downloaded before college at the end of the month. i have tried these solutions with no outcome, https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-fails-on-either-... and https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Material-Library-Low-Ima...
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Mark.Lancaster
@Anonymous
Your download is failing due to the method you're using.
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Also when sharing installation logs or other info, please make sure it does not contain serial #s.  In your case your installation log file does.  I will have the moderator remove it to protect your info.
Mark Lancaster
Yeah i know how to download it, thanks for the help. So any real solutions?
log file:
2016/6/13:15:17:26 es-09 LAPTOP- === Setup started on LAPTOP- by es-09 ===
2016/6/13:15:17:26 es-09 LAPTOP- Path_Length: 154
2016/6/13:15:17:26 es-09 LAPTOP- Current Directory C:\Autodesk\Inventor_2016_English_Win_64bit_wi_en-us
2016/6/13:15:17:26 es-09 LAPTOP- Launch
2016/6/13:15:17:26 es-09 LAPTOP- CommandLine /PK 797H1 /SN 900-36492359 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/Inventor_2016_English_Win_64bit_wi_en-us_Set...
2016/6/13:15:17:26 es-09 LAPTOP- Current Directory C:\Users\es-09\AppData\Local\Temp\_AI708C.tmp
2016/6/13:15:20:25 es-09 LAPTOP- === Setup ended ===
2016/6/13:15:17:27 es-09 LAPTOP-Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/6/13:15:17:27 es-09 LAPTOP- Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/6/13:15:17:28 es-09 LAPTOP- Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/6/13:15:20:24 es-09 LAPTOP- Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/SETUP...
2016/6/13:15:20:25 es-09 LAPTOP- PageOpen LaunchDialog
2016/6/13:15:26:03 es-09 LAPTOP- Install CustomCallback Info Invoking custom callback for details: [ACEINVADDIN] CB_FUNC=CBCatalogBrowserMessage CB_SOURCE=C:\Users\es-09\AppData\Local\Temp\_AI708C.tmp\Setup\AcadeUI.dll
2016/6/13:15:26:03 es-09 LAPTOP- Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=The manufacturer database is available for download. URLTitle=Learn more URLLink=http://www.autodesk.com/autocadelectrical-content-default-catalog-database-2016
2016/6/13:15:26:18 es-09 LAPTOP- PageOpen LicenseDialog
2016/6/13:15:26:18 es-09 LAPTOP- PageOpen ProductInfoDialog
2016/6/13:15:26:18 es-09 LAPTOP- PageOpen InventorFlavorSelectionDialog
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==DefaultLanguage: en-us
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==InstallName: INVENTOR
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ProductName: Autodesk Inventor 2016
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==DisplayName: Autodesk® Inventor® 2016
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==DeploymentName:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==SetupTitle: Autodesk Inventor 2016
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ConfigTransform:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ExeParams:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ProductCode: {7F4DD591-2064-0001-0000-7107D70F3DB4}
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==SupportLink:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==InfotainmentLink:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==MsiFileName: inventor.msi
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==AdminImageConfigName: Imgx64
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==AdminImageRoot:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==GetBaseDeploymentName:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==DeploymentLocation:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==DocumentLink: http://autodesk.com/inventor-install-2016-enu
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==InstallDeploymentShortcut:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ModifyDeploymentShortcut:
2016/6/13:15:26:18 es-09 LAPTOP-Inventorui==SetupLockType: 2
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==SetupNetworkType: 1
2016/6/13:15:26:18 es-09 LAPTOP-3entorui==SystemLocale: 1033
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==EvalMsiFilePath: C:\Users\es-09\AppData\Local\Temp\_AI708C.tmp\SetupRes\eval.msi
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2016\EULA
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==InstallLogPath: C:\Users\es-09\AppData\Local\Temp\Inventor2016Install.log
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==ConfigFile: C:\Users\es-09\AppData\Local\Temp\_AI708C.tmp\Setup.ini
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==SetupPath: C:\Users\es-09\AppData\Local\Temp\_AI708C.tmp\
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==NetworkLogPath:
2016/6/13:15:26:18 es-09 LAPTOP- Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2016
2016/6/13:15:26:26 es-09 LAPTOP- Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2016/6/13:15:26:26 es-09 LAPTOP- PageOpen ProductSelectionDialog2
2016/6/13:15:26:51 es-09 LAPTOP- PageOpen FullProgressDialog
2016/6/13:15:26:51 es-09 LAPTOP- Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/6/13:15:26:52 es-09 LAPTOP- Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/START...
2016/6/13:15:26:52 es-09 LAPTOP- Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/6/13:15:27:01 es-09 LAPTOP- Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/6/13:15:27:01 es-09 LAPTOP- Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\es-09\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2016/6/13:15:27:11 es-09 LAPTOP- Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2016/6/13:15:27:11 es-09 LAPTOP- Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/6/13:15:27:21 es-09 LAPTOP- Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/VCRED...
2016/6/13:15:27:21 es-09 LAPTOP- Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk Inventor 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\es-09\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2016/6/13:15:27:22 es-09 LAPTOP- Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2016/6/13:15:27:22 es-09 LAPTOP- Download Play CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/6/13:15:32:41 es-09 LAPTOP- Download Aborted CMILL http://edutrial.autodesk.com/NET16SWDLD/2016/INVNTOR/WI/{48B409A5-5562-47F4-8BE6-3195B4E6BAD8}/CMILL...
2016/6/13:15:32:41 es-09 LAPTOP- Install Autodesk® Material Library 2016 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
Mark.Lancaster
@Anonymous
What do you mean "Yeah i know how to download it, thanks for the help. So any real solutions?"  I gave you the steps and solutions to correct your installation issue..  The method you're using to download and install your application is cause the issue.  What don't you understand or can't follow?
In addition I told you don't post personal information such as your serial # (in your installation log file) and you do it again.  Are you paying attention or am I wasting my time trying to help you.
Mark Lancaster
Mr. Lancaster, i apologize. I honestly thought you were a bot who always referred someone with an install problem to this virtual agent which i assumed was just a tutorial showing how to install it. Thank you for the help, it worked correctly this time.
