Autodesk Desktop Connector
kennethHAKCS
kennethHAKCS
Hi Autodesk Team,
Currently, you can only select up to 80 projects to sync with File Explorer. Can we extend this limit to allow syncing all projects with File Explorer?
pendean
Community Legend
Community Legend
@kennethHAKCS There is no current ability to do that. Sorry.
And since Autodesk does not pre-announce changes, there is no indication that will change anytime soon either
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Is-it-possible-to-...
The tip from Autodesk: Regularly uncheck inactive projects in the Select Projects menu to free slots for new active ones.
Jason_S
Why would you want to?  80 is a lot and can't be worked on all at the same time.  Also, now that AutoCAD has the ability to work on ACC direct the needed has lessened for me.
Also, I do what penden suggests unchecking and checking others as needed.  I do this even with 6 projects connected via desktop connector.  If one isn't needed any longer uncheck and check new ones.
