Autodesk Application Manger/ Desktop App
Jroper
Jroper
I have a user that cannot get the new Desktop App from the old App Manager.  I've tried every proxy setting, but it should not need to be changed.  I checked to log in the C:\Users\jroper\AppData\Local\Autodesk\.AdskAppManager\Log folder.  I'm getting a download error.  Does this entry mean the server is down?  Is there a way to test the connection to tell if it is offline at the moment?
NFO 2016-06-06T08:15:40.242 TID(9104) AdNetworkAccessMgr::InitialSSLContext
 INFO 2016-06-06T08:15:41.597 TID(9104) AdAppMgrSvcStubImp::startAdAppMgrSvc: service is running
ERROR 2016-06-06T15:27:08.056 TID(9104) CmdTargetMgrImp::handleNetworkError: error=1879048201 Error downloading https://update.delivery.autodesk.com/appcast/services/appcastService/sam/v4 - server replied: Forbidden
 INFO 2016-06-06T15:32:31.520 TID(9104) AdAppMgrSvcStubImp::onServiceUpdating service updated
 INFO 2016-06-06T15:32:31.560 TID(9104) Started: C:\Program Files (x86)\Autodesk\Autodesk Desktop App\AdAppMgrLauncher.exe
 INFO 2016-06-06T15:32:31.577 TID(9104) Autodesk Application Manager ({8B0E5058-00E1-4A76-804B-957B2476201A}) stopped.
Otto
Hello Jroper
It looks like you're experiencing issues with the Application Manager. The following article(s) should help you resolve the problem:
Autodesk Forum Thread: Autodesk Application Manager
Autodesk Application Manager FAQ
How to Silently Uninstall Application Manager using SCCM
Error: Unable to run Application Manager
Autodesk Application Manager Error: SSL Handshake failed
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Jroper
I know you're looking for a solution..
But if it was me, I would stop depending on this interface and do it the old fashion way by going to the Autodesk web site and manually download the updates when needed.  But that's me...  Smiley Very Happy
Mark Lancaster
Jroper
I was able to solve the issue by simply installing the Desktop App from a separate downloaded source.  After the new app was installed, it was able to see the updates.  The old application simply stated that all products were up to date.  Thanks for advice bots and humans.
