Sometimes, remnants of a previous installation remain on your system after you remove software through the Control Panel. If so, you can’t install new versions. Use the Microsoft Installation Troubleshooter, previously called Fix It, to remove these remnants.
- Go to Fix problems that block programs from being installed.
- Click Download.
- Click Run or Open. Then follow the steps in the troubleshooter.
