AutoDesk An error occurred while preparing the installation
eceilaydaa
Message 1 of 25
eceilaydaa
I have tried everything on Youtube. I still get the same error. Please help, I have urgent need.
Replies (24)
Message 2 of 25
eceilaydaa
this is the screenshot
Message 3 of 25
cadffm
Contact Autodesk.. ask for help to install.
Sebastian
Message 4 of 25
mdavis22569
@cadffm NOOO..
@eceilaydaa Don't use the Webinstaller.. Try the full Browser installer:
Try this:
P1:
https://efulfillment.autodesk.com/NetSWDLD/2024/ACD/CC46AD7F-5075-3702-B2BF-CFCC5AB8468B/SFX/AutoCAD...
P2:
Download both fully then try installing it.
Mike Davis
Message 5 of 25
cadffm
"NOOO.."
Sebastian
Message 6 of 25
mdavis22569
Why rush to send him off to another support ... it's an easy fixed normally. I see it daily.
Mike Davis
Message 7 of 25
cadffm
Right 👍
It's like: Why asking in forum, if the message saying Ask AutoDESK
Sebastian
Message 8 of 25
mdavis22569
It's a known issue.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-install-...
Mike Davis
Message 9 of 25
eceilaydaa
I have contacted the support actually they directed me to the forum
Message 10 of 25
mdavis22569
Did you try my 2 links @eceilaydaa   Download them both and then try installing it?
Mike Davis
Message 11 of 25
eceilaydaa
tunately it didnt work 😞 it didnt give the same error but just closed the application after it extracted/downloaded
Message 12 of 25
cadffm
Wow,
unexpected for me.
Sebastian
Message 13 of 25
eceilaydaa
this one perfectly downloads but then nothing happens
Message 14 of 25
mdavis22569
2 should work now
Mike Davis
Message 15 of 25
eceilaydaa
the download from the screenshot is complete but nothing starts 😞
Message 16 of 25
mdavis22569
Do you have the fire wall / anti-virus off?
Clean out your C:\Autodesk folder completely, as well as your DOWNLOAD folder.   Only having my 2 links there.
Clean out the %temp% folder
From there right click on 001_002 and click Run As Admin ..   Pick C:\Autodesk for the download location
Mike Davis
Message 17 of 25
eceilaydaa
I have the antivrus systems off. I deleted the C:\Autodesk folder. Should I Clean out the %temp% folder completely? it says preparing but still nothing happens
Message 18 of 25
t_shanr
@eceilaydaa Hi, Could you open services and verify that Autodesk Access Service Host is running? in case if it is not then can you right click on it and try and start it. Do let me know how it goes.
***In case if you don't see anything called Autodesk Access Service Host in Services, then you will have to download and install ODIS : https://emsfs.autodesk.com/utility/odis/1/installer/latest/AdODIS-installer.exe
The general idea is that the Access service host service should be running fo you to install the applications as all the newer Autodesk applications utilize the on demand installer(ODIS) to install
Message 19 of 25
eceilaydaa
how can I open services?
Message 20 of 25
t_shanr
In Windows search type "Services" or press Windows+R on your keyboard and type in services.msc and hit enter, that should open Services for you.
