- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Not sure what is going on, I've attached my log file since I seem to be hitting several errors.
Your download is failing due to the method you're using.
Click on the “installation” link in my signature and follow the recommended steps that are provided in that posting. Make sure to review all of the acceptable solutions (marked in green) since these steps will change over time.
For example the most recent solution now includes a link to the major 2017 product line (http://forums.autodesk.com/t5/installation-licensing/community-downloads/m-p/6314550/highlight/true#... making it easier for the end user to download/install the latest version of the software.
If your installation does fail after these recommended steps
• Review this posting: http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-fil...
• If that doesn’t help, attach your installation log file here in a text file format and someone will review it for you. You can also locate your installation log file based on this posting: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Using-...
• When attaching your installation log file make sure that any personal information such as your serial # is removed.
Good luck on your installation and hopefully this information will resolve your issue.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Thanks so much, it seems my anti-virus was getting in the way.
Now I won't fail at my new job 🙂
